Finding the serial number
You might need to know the serial number of your machine when calling for a service. To check the serial number of your machine, follow the steps below.
[Note]
The serial number is written on the beginning of all the machine reports.
  1. Tap Settings > Management > Report > Usage Counter > Print from the home screen or Apps.
    OR
    Select the Information tab > Usage Counters From the SyncThru™ Web Service.
  2. Check the serial number.
