There are few ways to clear memory to ensure the memory capacity of your machine. Select one of the ways below.
Check the stored documents before clearing machine memory.
Tap from the home screen or .
Touch and hold folder or document you want to erase from the list.
Tap
When the fax memory is full, you can erase stored fax memory. There are two ways to erase the fax memory, follow the steps below:
Print received fax(es). Fax memory will automatically be erased.
If you clear fax memory without checking the fax job by printing it first, you might erase jobs that you do not want to. Be careful not to erase important documents. |
Select the tab from the display screen.
Select the job(s) you want to erase than press .
If you want to erase all the jobs, press .
To erase only fax jobs on the list, select fax jobs with in the list and click .
