This chapter explains how to use a USB memory device with your machine.
This chapter includes:
To use the USB feature, press on the display screen.
If you want to use this feature, you need to insert a USB memory device into the USB port on your machine. |
USB Display: Displays information of the folder or file.
(): Moves back to the upper level.
: Makes a new folder in the USB memory device.
Format : Formats the USB memory device.
Rename : Changes the name of the selected folder or file.
Delete: Deletes the selected folder or file.
Print : You can directly print files stored on a USB memory device. You can print TIFF, JPEG, PDF, and PRN files (see Printing from a USB memory device).
Scan to USB: Sends you (see Scanning originals and sending to a USB memory device (Scan to USB)).
USB memory devices are available with a variety of memory capacities to give you more room for storing documents, presentations, music and videos, high resolution photographs, or whatever other files you want to store or move.
You can do the following on your machine using a USB memory device:
Scan documents and save them on a USB memory device.
Print data stored on a USB memory device.
Format the USB memory device.
Your machine supports USB memory devices with FAT16/FAT32 and sector size of 512 bytes.
Check your USB memory device’s file system from your dealer.
You must use only an authorized USB memory device with an A plug type connector.
Use only a USB memory device with metal-shielded connector.
Only use a USB memory device that has obtained compatibility certification; otherwise, the machine might not recognize it.
Insert a USB memory device into the USB port on your machine.
Do not insert the USB memory device to other ports except the ports which is as shown below the image. If you insert the USB memory to other ports, the machine shows warning message on the display screen. |
You can directly print files stored on a USB memory device. You can print TIFF, JPEG and PRN files. You can select 50 files and print selected the files at once.
USB print option supported file types:
PRN: Only files created by provided driver with your machine are compatible. PRN files can be created by selecting the check box when you print a document. The document will be saved as a PRN file, rather than printed on paper. Only PRN files created in this fashion can be printed directly from USB memory device (see Printing to a file (PRN)).
TIFF: TIFF 6.0 Baseline
JPEG: JPEG Baseline
PDF: PDF 1.7 and below
In case of 8bit CMYK JPEG files, Job could be cancelled. |
To print a document from a USB memory device:
Your machine automatically detects the device and reads data stored on it (see About USB memory device).
Press from the display screen.
The machine shows all files in the USB memory device.
Select the file you want to print. You can also select multiple files if you want to print a number of files.
Press .
Press the appropriate option.
: Selects the number of copies.
: Selects the color mode of copies.
: Selects the machine to print copies on both sides of the paper.
: Allows you to scale your print job to the selected paper size in the tray regardless of the document size. Select a tray, and press .
: Selects a tray that contains the paper to be printed.
: Sets the machine’s various output options such as copy output option (see Deciding the form of copy output).
Press
() from the control
panel to begin printing.
After printing is completed, you can remove the USB memory device from the machine.
You can delete image files stored on a USB memory device one-by-one or all at once by reformatting the device.
After deleting files or reformatting a USB memory device, files cannot be restored. Confirm that you no longer need the data before deleting it. |
Press the file you want to delete.
If the file is in a folder, press the folder name. |
Press .
Press when the confirmation window appears.
Press .
