This guide provides information on purchasing supplies, accessories and maintenance parts available for your machine.
This chapter includes:
Available accessories may differ from country to country. Contact your sales representatives to obtain the list of available accessories. |
To order Samsung-authorized supplies, accessories and maintenance parts, contact your local Samsung dealer or the retailer where you purchased your machine. You can also visit www.samsung.com/supplies, select your country/region, and obtain information on calling for service.
When supplies reach their lifespan, you can order the following types of supplies for your machine.
Depending on the options and job mode used, the toner cartridge’s lifespan may differ. |
You must purchase supplies, including toner cartridges, in the same country where you purchased your machine. Otherwise, supplies will be incompatable with your machine since the system configuration of these vary from country to country. |
Type |
Average yield[a] |
Part name |
Toner cartridge |
Average continuous black cartridge yield: 20,000 standard pages |
CLT-K809S (Black) |
Average continuous colored cartridge yield: 15,000 standard pages (Cyan/Magenta/Yellow) |
CLT-C809S (Cyan) CLT-M809S (Magenta) CLT-Y809S (Yellow) |
Imaging unit |
Approx. 50,000 images |
CLT-R809 |
Waste toner container |
Approx. 100,000 imagesc |
CLT-W809 |
[a] Declared yield value in accordance with 5% coverage. |
Disconnect the power cord.
Never remove the control board cover while the power is turned on.
To avoid the possibility of an electrical shock, always disconnect the power cord when installing or removing ANY internal or external accessories.
Discharge static electricity.
The control board and internal accessories (network interface card or memory module) are sensitive to static electricity. Before installing or removing any internal accessories, discharge static electricity from your body by touching something metal, such as the metal back plate on any device plugged into a grounded power source. If you walk around before finishing the installation, repeat this procedure to discharge any static electricity again.
Activating the added accessories in the PS driver properties.
After installing an accessory such as an optional tray, PS driver users must do the additional setting. Go to the PS printer properties and set the added accesorry activated.
When installing accessories, the battery inside the machine is a service component. Do not change it by yourself. There is a risk of an explosion if battery is replaced by an incorrect type. Dispose used batteries according to the instructions. |
You can purchase and install accessories to enhance your machine’s performance and capacity.
Accessory |
function |
Part name |
Cabinet Stand |
You can place the machine on the ergonomically-designed cabinet which lets you reach the machine conveniently. Also, you can easily move the cabinet with its wheels, if necessary, and store miscellaneous items like papers into the cabinet. |
CLX-DSK20T |
If you are experiencing frequent Paper Source problems, you can attach an additional tray. The optional tray can hold up to 1,040 sheets. You can print documents in various sizes and types of print materials in the tray. |
CLX-PFP100 |
300-Sheet Inner Finisher |
This Inner Finisher allows you to sort, group and staple printouts. |
CLX-FIN50S |
Working Table |
You can place an external authentication device or miscellaneous items on the working table. |
CLX-WKT000 |
Fax Kit |
This fax kit allows you to use your machine as a fax. |
CLX-FAX160 |
FDI(Foreign Device Interface)Kit |
This card is installed inside the machine to allow a third party device such as a coin operated device or a card reader. Those devices allow the payfor-print service on your machine. |
CLX-KIT10F |
Hard Disk Kit |
This hard disk kit will help the machine to be used in various ways. |
ML-HDK471 |
Job Separator |
This Job separator will help the machine to collate printouts. |
CLX-JST100 |
If you experience frequent paper jams or printing problems, check the remaining lifespan of supplies. Replace the corresponding parts, if necessary.
Press > > from the main screen.
Check the supplies life.
Press for return to the previous screen.
